FordNut74 and everybody else,
I'm taking out everything in my 1997 except the fuel tanks. I'm going to put in an electric diesel system and stand alone electric veggie system. I now have a greasel kit so there are some parts that I will be reusing such as the diverter.
I was looking at a diagram of the FN74 settup and I will have something in common with that system. That is a looped return and VERY short fuel lines to the heads. What happens when air gets into the line? I would imagine that you wouldn't know it until the injectors starve quickly and completely.
How do you deal with this on your system?
I was wondering if there could be a ball valve that is normally open until it senses back pressure (pump on with looped return). Once an air pocket reaches the ball valve there MAY be a drop in pressure, opening the ball valve to the normally opened possition and diverting the bubble into a return line back to the tank. Honestly I think the air pocket would contain the same pressure as the fuel determined by teh regulator.
But, am I on to something here or do you have another idea?
Any suggestions would be greatly appreciated.
