OK master techs, Does this sound correct to you? I had located a "bubble" on one of the AC hoses a couple of weeks ago. My belt has also been squeaking for a few weeks. I assumed (big mistake) that they were unrelated. I assumed that it was either a bad belt or the tensioner pulley. I took it to the dealership today and the service manager called me back this afternoon and said that the AC compressor was shot and that they needed to replace the compressor, the "bubbled" hose, the accumulator(?)and the orafice(?). He also said that there was "metal in the system" and the system would need to be flushed. OVER $1400!?!!
I guess here is my question, Could my AC still work if this was true? My AC is still cold as it always was. The squeak got worse when I turned on the AC and got better when I turned off the AC but the AC was still blowing really cold air. I know the hose needs to be replaced due to the defect but the compressor also? Can there be "metal in the AC system"? I was told that if it is not repaired that one day the compressor could "stop all together and then I would throw the belt". IS this all BS or does this happen? I have approximately 47,000 miles on the truck.
