RE GPs:
Your wiring harness could be bad, grounding to that controller or the block or both could be bad.
RE Injectors:
Make sure to bleed the air out of the high pressure side or it'll take ages and ages of cranking to get the thing to try to fire. Do this by just loosening up one of the injector fuel hard lines at the injector, and crank (being mindful of not cooking your starter motor, 10-15 seconds, wait 30-60, repeat) until fuel comes out. DO NOT PUT YOUR HAND AROUND/OVER THE LOOSENED INJECTOR YOU WILL DAMAGE YOURSELF -- the fuel sprays out with more than enough pressure to cut you, and to inject itself into your blood stream.
Once you start seeing fuel dribbling from the injector you've loosened, tighten it back up. Your explanation of, and order of events makes almost no sense so I'm sort of guessing at what you did.
If you've got no WTS in the cab then light the bulb could be out, or the ground for the bulb (or chassis ground too) could be bad. Any time the relay is closed it should be getting power to that bulb. Could also be wiring issues too.
On the 1985 I've never had "fast cycling" problems, just stuck on, and nada. I actually thought only the later bullet style connectors with the different (Positive Thermal Coefficient/PTC) controller would fast cycle, but I could be totally wrong there.
