I'm new on this platform but need some help with an 85 International 6.9L diesel in a Ford E350 Econolinee RV (non-turbo). I installed new fuel return hoses/clamps on 2-4-6-8 injectors due to a leaking hose. All was okay-started, idled okay. Then it started, idled for a bit then died at idle. I replaced the fuel filter, bled the filter air. Same- started, then died after a minute. I added fuel stabilizer to fuel in rear tank that has recently- added fuel. It still starts, then dies at idle affter about a minute on both tanks. Have read a thread on this platform from 2016, but not sure what I should do.
Update- found fuel tank selection valve leaking fuel, am replacing. Could this limit fuel flow and air in fuel line?
Any suggestions are welcome
Administrator
Yes, a leaking selector valve on the fuel supply line would let air into the system and eventually starve the engine of fuel.
I think that should fix it once the valve is replaced.
If not, post back in this thread and someone more familiar with the 6.9L will help out.
