I have a 1989 Ford F-350 7.3l Diesel and am wondering:
1. How many glow plugs have to fail to make the engine?
A. Hard to start
B. Not start
I have:
1. Checked all the glow plugs with a continuity tester and they test OK
2. Checked the glow plug controller (both voltage & timing) and it is OK
Here are some facts/observations:
1. Summers temperatures when trying to start are 70-80 degrees
2. The engine always starts after the block heater is plugged in for a few hours.
3. The engine runs strong once started
4. There are a few glow plugs that are hard to reach and I am wondering if 2-3 being out can cause this issue in summer temps?
5. I do notice that there is some air in the fuel filter (press on value occasionally and fuel does not squirt out, some air (for 2 seconds, then fuel or air, no fuel until it cranks a few times) (Could it be related to fuel delivery?)
I would like to also know if anyone has some ideas about the best tool/way to get to the 3 or so glow plugs that are mid-engine and seem to be blocked by the metal fuel lines? The F-350 is a van with the typical problem of the engine not being out in the open as a truck with a hood would be.
Thank you!
A. Hard to start
B. Not start
I have:
Thank you!
