I remove fuel filter to add sea breeze field fuel filter to the top with sea breeze lubed the Rubber seal installed the fuel filter hand tight turn down the motor it started up right away ran for a few hours when I try to turn it back on it would turn on for at least a couple of minutes then die I want a head and released Air from the housing of the fuel filter connection there was air coming out kind of scratching my head what else could be going on any help would help thank you
Does your truck still have the two piece fuel filter? It is possible that it wasn't tight enough, or otherwise leaking and allowed the filter to drain.
