Lol, tore the whole front axle out of it and found the axle tag. Bearings looked rather worn, but rather evenly worn across all the bearings. I almost missed a camouflage axle tag. Rusted in place after 33 years.
Posted up with a wire wheel, surprised to find it was still readable.
Lots of credit to those who took step by step pictures on their tear down and reassembly. I probably would have gone through 300 pairs of Nitro gloves to keep taking them off and put them back on to do that. Anyway, considering the age of some of these parts have been together, I only had a few that put up a fight. Probably the usual culprits, the pivot bushings of course. Much easier on the bench with air tools. Passenger side knuckle took a couple full blows with an 8 lb Sledge. The grease and all the ball joints had turned to dark powder. Same for the original U-joints in the front axle. One bearing race took 18 tons to get a pressed in. That one had me worried. Used all Timken bearings, identical to what I pulled out. This truck doesn't get a lot of use, maybe 2500 miles per year. Either when it snows, we use it to pull the boat to the lake, and pull our dump trailer around. It's nothing special to look at, it's just been super reliable and very useful. Figured after 5 years of using it I could justify putting a little money into it, LOL.
All of the races look pretty much like this one, definite wear pattern.
Knew you bolts showed up today so now the fun begins, putting it back together
