Took my truck to a shop to have the problem diagnosed. They replaced the wire harness connector going to the coil pack because it was corroded and letting water enter the connector. Cost $300. While inspecting the coil pack male ends they noticed one pin broken. Said I need a new coil pack at cost of $775 counting labor.
This tranny was overhauled about three years ago. It has been working pretty good even with the lite on. If I press the OD button it will shift back and forth to over drive normally. Two days ago
I noticed a vibration when I speed up in any gear. The shop believes its caused from bad U joints.
My question. Is there any difference in coil packs as long as it is for a 1992 F250? Does any one have a part number or source of supply
Any comments or suggestions is appreciated.
