1994 F-250 7.3 dit
I pulled the heads. Went back with new head gaskets and new head bolts. While torquing the head bolts from 85ft/lbs to 105ft/lbs I broke a head bolt in between on of the cylinders.
where should I go from this point? What are my options?
I'd remove the head, and the broken bolt, and then re-install the head correctly. The gasket hasn't been run, so it should be good to re-use. I'd also get a torque meter to put between the torque wrench & socket, to check if the wrench is calibrated correctly. If they don't agree, I'd send the wrench off for rebuild, or get one that's right before breaking more bolts.
Something like this: https://www.amazon.com/dp/B009GLISI0
To add to what Steve said, make sure that you are using the correct length bolt. They can't be bottomed out when torqueing them
