1 - 10 of 10 Posts
what can i do to get shift point to not shift so soon ?? when towing it seems to shift into over drive way to soon ?? before 40 mph anyhelp thanks
Yeah, use tow mode.
The only way that I know of to change shift points is to get a chip or programmer
Use the button on the shift stalk. Turn the O/D off until you're at the speed you'd like it to shift into it.
^^^^^ That's exactly what the OD button is for. Any sane designer would have opted for a shifter with seven positions, for P, R, N, OD, D (or 3), 2, 1. Ford, in their infinite wisdom, opted for a pushbutton instead of an actual shifter position. Maybe they were trying to market to former '63 Valiant drivers :dunno: ?
Yeah, use tow mode.
'95 doesn't have tow/haul mode. My '94 will shift into OD at about 37MPH with no load. Fiver weighs about 9500 with stuff loaded, and I just press the pedal a little bit more to force a higher rpm shift.
I will manually cancel OD for climbing a hill, and even downshift if needed to keep RPMs up.
Yeah, OD on/off. Wrong "name," but everyone knew what I meant.
OD off and tow/haul mode are completely different.
1 - 10 of 10 Posts
