anyone have any issues with the steering binding going down the road? I will get some wander and when I try to turn, it binds and then jumps to wherever I have turned it. Kinda scary to drive. It seems to do it if I have been in a field or something then back on the road
You want to check for a seized front axle u-joint.
I have looked at all of that. I have had it jacked up, all the sterring unhooked. I can turn spindles on both side back and forth with no trouble, lock the hub in and rotate tire and nothing. Does this thing have a rag joint in colum that could be headed south? Was also wondering if a sterring stabalizer would keep tie rods from moving up and down so much. was thinking it is binding
X2. When you had it apart did you spin the wheel when you had it up and turned either way? Have you also checked the tie rods?
