pukuja, FYI, the shore power probably only powers the house batteries, not the starting batteries, unless there's an isolator switch on it. Check all locations where lights, sirens, switches were removed first and eliminate any of those possible problems. What are the chances that 2 separate alternators would die at the same time? Finding and correcting electrical problems on a decommisioned ambulance takes time and diligence! Cheers!By any chance, would you have a wiring diagram for a 1999 E350 with a Wheeled Coach ambulance box on it (fully functional)? I contacted Wheeled Coach and they don't have any diagrams for one that age. I have a charging issue. After spending $940 to have two new alternators put on to replace the old ones, the problem remains. After a full charge, the two batteries in the ambulance plus the one in the cab die after a day and a half, even while it is plugged into power with the 20amp shore connection.
