I have a 96 7.3 with 248xxx on it
The truck starts and idles fine but has a constant Haze of white smoke, when I press the gas it’ll only pull 2,000 and the smoke gets worse really thick I can eventually get the truck to rev higher and better and the smoke will clear up some but a soon as I kill the truck it will be just as bad again, have replaced all computers could any of those be the problem I got them of a parts truck cuz of mine **** the bed any help would be appreciated
I would look at your fuel system. A lack of fuel pressure will cause white smoke from bad atomization of the fuel at the injectors.
It's also possible you have a cracked injector nozzle. Does the smoke stink bad and burn your eyes? If so it would be unburned fuel. A coolant leak could also be a cause of white smoke.
I doubt it's electronics related.
I agree with Kevin, look close at the exhaust manifold on each side and see if one is wet. You may have a bad injector cup.
DENNY
