Hey everyone I need some help extremely bad...im $1500 in hole from guessing, and i'm losing my mind....its a tow truck and I can barely get over 45-55 mph with or w/o a load....I've changed the lift pump due to it leaking at the housing thinking that may have cause a issue (no change) then doing some reading and seeing other people having the same issues and replacing the turbo so I tried that (no change) so here I am....revs in neutral around 2-2500 with some blue smoke, and its not throwing any codes.
I am not sure if you have fixed your issue or not by now, but have you pulled the codes on your truck yet?
