I have a 1997 ford f350 crewcab 4x4 with 119,xxx miles. The issues I am having has put between a rock in a hard spot. Truck runs and drive as it should I don't notice anything different with it idling, but when you go under hard acceleration the truck hiccups as if there is an air pocket in the fuel system, I have replaced the fuel bowl (400 bucks) and the fuel pressure sensor. I have also cleaned the both fuel tanks and replaced the fuel pump in the tanks as well. I have been fighting this for 2 weeks and need some help.
· Super Moderator
Just what did you replace in the tanks? There are no fuel pumps in the tanks on a 7.3. The only fuel pump in in the valley near the turbo and is mechanical.
Do you have any modifications to the engine in the truck?
