I have a 1997 CC 4x4 that started just fine last weekend. this weekend i was installing some guages and now all the sudden it wont start. i havent even hooked power to the guages yet because i dont want to until i can make sure they are correct.
So as for my no start issue...HPOP is full, fuel bowl is full, wait to start acts normal, no check engine light unless im cranking it over. all fuses are good to include number 22, changed CPS and that is where i get stumped. before i changed the CPS there wasnt any tach movment and after the change there is a very small amount of movement that i wouldnt even consider movment. Im about to change the CPS again but i would really like to get some input first. Also i would like to note that there is no smoke coming from the tail pipe. the truck is slow cranking also since i have tried several times to start it but i have had a charger on it with the start setting and it cranks over very fast with the charger on it.
So how much should my tach move when starting? i really never payed attention to it before like i should have. Is there anything else that would control tach movment that im missing??????? thanks for all the help in advance
