Ok, calling all Dana 60 experts.......... Here's my issue. I have a 1997 F250HD PS 4wd Ext Cab. 4" Skyjacker lift, 35" tires. After eating through ball joints and bushings on the TTB D50 twice, I decided to put in a D60 solid axle. I acquired one from a 1994 F350. Had it rebuilt professionally, regeared to match the rear end, new everything..............except the knuckles. The original 97' knuckles are different and therefore the calipers wouldn't fit on the D60. So I just used the D60 pin type calipers and rotors. Basically, I bolted on the entire 1994 F350 D60 assembly; rotors, calipers and all, onto my 97' F250. I put on new calipers (94 F350 calipers and brake pads). After getting it all installed, everything fit great, bolted right up, but..............my braking SUCKS. My pedal goes all the way to the floor and it barely stops. Went through a gallon and a half of new brake fluid bleeding the brakes and purging the system. My questions are these:
1) Anyone know of any issues with using the 94' F350 Calipers with the original F250 master cylinder?
2) If I have to, will the knuckles from my 97' D50 TTB fit on the 94' D60 so I can go back with my original rotors and calipers?
Any suggestions, advice, insight, help, prayers, and/or ALL of the above would be greatly GREATLY appreciated.
jrgrtx
USMC
Sempr Fi
jrgrtx
USMC
Sempr Fi
