I have a 1997 f350 power stroke. It started running really badly with hardly any power. I used a cheap code reader, and there were no codes. I bought a really nice reader and got the code for the CPS.
This truck would not rev above 2500 while in park or neutral. After replacing the CPS, and replacing the fuel filter, it ran much better. It will now turn the rear tires over like it used to.
The problem is that it will not rev over 2800 rpms while in park or neutral.
Is this common? Does this truck have a neutral rev limiter? It revs up to
the 2800 rpm's really quickly and smoothly now.
Is this anything to worry about? I have not pulled any weight to really check it out, and it is throwing no codes now.
I called the local ford dealer, and they had no information at all, told me to
bring it in.
This cps was just replaced before about a year ago. Is this common?
Any information would be greatly appreciated.
bring it in.
