1 - 9 of 9 Posts
I have a 2005 f-250 and I am going to buy some Moto Metal 951's in 20x10's and wanted to get some input on both the rims and what kind of luck people are getting from either the BFGs or Toyo's in a 325-60-20 or similar size....which tire is better??...thanks.
You are going to have to get more than 2.5" of lift in the front for 20x10 and either set of these tires. I have 20x10's with 325/60/R20 and a 2.5" leveling kit in front. The tires rubbed terrible in front when I first got them put on. I had to do some serious trimming to get the rubbing under control. If I had to do it over again I would go with a narrower wheel 20x9 probably and a 35" tire that is not over 35" tall like the BFG's and Toyos. Pro comp for example makes a 325/60/R20 that is only 34+ tall.
ebolavirs, thx for the great information. I should have mentioned I have already added a Ranch leveling kit that replaces the front swing arms, springs, etc, not sure how much it raised the truck but it may be 2.5 in the front. I pretty much do not want to do more than a 35 inch tire for wheel well clearance reasons. Any other thoughts for me as I can use all the help I can get.
I have the stock 20" wheels on my truck with the Toyo 325/60/R20 All Terrains and love them! I only have 2.5" of lift, but with only that much lift you need to go with a narrower wheel. If you go with say a 20x10 then the tire will sit further out because of the backspacing of the wheel; therefore, you will need more lift to let the tires turn inside the fender and wheel well. If 20x10's are what you want then I would go with a 4.5" lift at least! Choices, Choices!! /ubbthreads/images/graemlins/shrug.gif
1 - 9 of 9 Posts
