did you have the speedo corrected for the bigger tires? if you didnt, it will show a lose of mpg .
No, I have not made any corrections to the truck, but I can calculate the conversion and keep a spreadsheet that takes the odometer readings and converts them into actual miles. Then I take the actual gallons bought and calculate the true MPG. In my case, it goes something like this:
Conversion for bigger tires:
Old tires (235/85R16) were 31.7" tall (16" for the rim, then 2 times 85% of 235mm); New tires (285/70R19.5) are 35.3" tall. That means for every revolution, I actually travel 1.11 (35.3/31.7) times as far as the odometer said. So if it clocks 100 miles, I actually covered 111 miles. That's easy enough to correct for.
Conversion for gears:
Old gears were 4.10's and new ones are 4.88's. That corrects me in the other direction by 4.88/4.10 = 1.19.
So the net net (I think) is 1.11/1.19 = 0.93. That means for every mile shown on the odometer, I actually travel 0.93 miles.
I think the above is correct, but strangely, it does not match what I see on the road. I know that work is about 35 miles one way. I expected to see 35/0.93 = 37.5 miles on the odometer. In fact, I saw LESS than 35, something like 10% less. So something weird is going on. I also have a Detroit Locker in the rear, but I don't think that matters.
Anyone have an idea why I get what I get?
RL
