2000 7.3 takes about seconds of turning over to start and once it’s running if you shut the key off and start it immediately it fires up instantly but if you wait 20 seconds or more it’s back to about 10 seconds temp doesn’t matter does it hot or cold weird part is if I crank and and shut it off but leave the key in the on position I can come out 2 minutes or an hour later and it’ll fire right up also but key has to be left on
Fresh oil and fuel filter
New batteries
Icp is unplugged
Hpop reservoir is full at all times
Jumped gpr for a minute no change
Left plugged in for an hour no change
Cycled key 6 times no change
Runs fine once it’s started
New batteries
Icp is unplugged
