I have a 2000 f350. 4dr. Dually. New 6spd. I am getting a newer engine and all 4x4 parts except t-case and frnt shaft.
I am getting:
Engine
Front and rear matching axles and suspension. Complete hub to hub.
4x4 tail shaft for 6spd to modify my trans.
Brake lines.
All shocks.
Besides t case and front shaft what else do I need.
Are there any write ups? Donor truck was a 03 dually
The tranny will have to come completely apart to replace the output shaft, which is a lot of work, especially if you haven't worked on one before. You'll also need a rear tranny housing that the t-case bolts to. I have heard, but can't confirm, that t-cases for auto and manual trannies have different input shafts to mach up with the somewhat different output shafts.
KL is right. the input shaft for the transfer case is different. you can either tear it apart and replace the shaft or get the other t case.
