Very periodically the truck will go to idle at about 65 mph. Numerous checks and part changes later it appears that it has more to with ram than speed. When it happens, keep coasting and within 5 to 20 seconds (a lifetime) it goes back to normal and away you go. Only because just every motor part and computer has been changed have I landed on the train. Diode, bad wire, loose thingamajig, ANYBODY else experience this ?
White '99.5 F250 SD XLT 4x2, 7.3PSD, 6spd, SuperCab, Short Bed - purchased Oct'05
Well, I hear all the 7.2s had a tendency to do that. But the 7.3s on the otherhand... :) Is the CPS or ICP sensor one of those "every motor part"s that has been changed? I would also suggest looking at grounds, the issue could be a bad connection that momentarily kills the computer. Snd any codes?
Could also simply be the Apps/tps.
Sent from my SM-G988U using Tapatalk
