I am new to this site, I am 15 years old and recently purchased a 2000 F350. I bought it off AuctionTime and the description didn’t sate the problems it had. First off, the previous owner wired a whole lot of stuff to it that shouldn’t be wired. I guess the solenoid is bad because he added a push button start. When you close the diver‘s door only one out of the two latches work so the door will part open. Then the ”door ajar“ light stays on. I even tried the Wd-40 hack. When I get to a stop the dome light stays on and sometimes doesn’t go off. The license plate lights wires are cut, the power locks don’t work and the key fob doesn’t lock the doors either. There is also an oil leak and power steering only works when you press the accelerator. Cruise control doesn’t work either. I probably wouldn’t had bought this truck if I knew of these problems but now that I have it Im not sure what to do. Any advice would be greatly appreciated. Thank you very much!
