Hi all, I have a 2000 Isuzu NPR. When I turn the key, I get nothing. No dash lights, nothing. I can jumper a couple of points at the ignition switch and then get dash lights, glow plugs, etc, as if it was working fine. I can also then turn the key and engage the starter and it starts and runs fine (I think the turbo is stuck, but that's another matter). As soon as I remove the jumper I lose dash lights, etc. I have to manually move the stop solenoid to shut off the engine. This started as an intermittent problem, most notably when I used the left turn signal (almost like that shorted something out). I could hear a loud click under the dash as if it was some sort of master relay misbehaving. I had an automotive electrical guy come out and he thinks it is a bad fusebox (the one in the glove box). He jumpered a couple of points and said "See, it works when I jumper this". But when I remove the key, the dash lights were still on, so I doubt he found the root issue here.
Anyway, I'm open to any suggestion here, I really need to get this thing back on the road so I can stop renting U-Hauls. Any thoughts or suggestions would be greatly appreciated. Thanks!
