1 - 10 of 10 Posts
I don't know if this is the right forum, so please let me know if it should go somewhere else.
My goal is to get a functional serial interface to the DLC. From what I can tell, the PCM talks in J1850-PWM but uses a non-standard data stream - so any OBDII-compliant code scanner will recognize it and sync, but will usually not get useful data. I should be able to handle the physical signaling just fine (going from PWM at 41.6 KB/sec to a common serial interface like UART). Problem is I don't know what to do with that data stream, or how to talk back to the PCM. Does anyone have a protocol specification, or even know the name of the protocol?
Discussion Starter #2
Okay after doing some reading, it looks like Ford uses what they call SCP (standard corporate protocol). J1850-PWM was defined as a subset of SCP. I should be able to use an ELM327 (probably) to get a translated data stream from the bus, or program my own PIC to get a raw datastream. But I don't have any idea how most of the protocol works. So does anyone have specifications on SAE J1850-PWM or SCP (which would be even better)?
I don't have much on the actual mode 6 data or how it gets translated to something readable, but this site lists a lot of info on the OBD systems and says that you can see what the mode 6 data means.
Motorcraft Technical Resource
I picked a couple of years at random, but couldn't see much about the mode 6 data. What I know I've learned from others: TID 53 is constant misfire info (sometimes TID 52, depending on year). I'd love to know more, but I'm not much for programming like that...
Discussion Starter #4
Thanks... that might just tell me enough of the code mapping to get some progress.
This is all I have:
a long long road ahead of you
i can point you to some videos that might help you
The good news is he posted this 3 years ago and so he has a good head start ?
1 - 10 of 10 Posts
