Good evening, I've done quite a bit of searching of the forum and troubleshooting, and I've successfully made it worse.
I have a 2001 Ford Excursion 4x4 with the 7.3 and approx 200k trouble free miles on the clock. Starting about a month ago, it died randomly on me riding down the freeway one day. I was able to knock it in neutral and get it restarted, but it died a couple more times on my trip. This is the first I had experienced anything like that.
I went home and checked some things under the hood and settled on loose battery terminals, cinched them down, and haven't had an issue until this week when it died in town at a stoplight on me.
Knowing the CPS is a common issue with these trucks, I ordered a motorcraft (dark blue one) and installed it. I also checked the IPC while in there, no oil in the plug, and checked the wiring harness by the driver side valve cover for chafed wires. All good on both fronts.
Truck started fine, but about 10 minutes into my test drive it started dying at stop lights when I would try to accelerate. The stalling problem was much worse and more frequent than before. Eventually I got to the point where she will not restart, and with the ignition keyed on, it will not accept an OBD2 code reader (I tried 3, one of those Amazon wifi ones, my edge monitor, and the AutoZone reader).
I'm wondering if the PCM is toast? Or was my motorcraft CPS a dud out of the box? (Bought from Amazon, but it was sealed in Motorcraft packaging, had good reviews, and seller states is genuine) Any help is appreciated because I have a 9k lb boat anchor right now!
