1 - 9 of 9 Posts
Is it normal for my coolant temp to be running at 250 degrees, while just idling and just started.
Where are you getting that number? If it's from a OBD2 port linked gauge, then know that unless you have a manual transmission, that's a fictitious number. The PCM doesn't monitor coolant temp. Switch to watching engine oil temp. That one is real.
If you have a gauge and you're seeing actual 250 degrees, then you've got a major problem.
Yes, I am reading it from a SCT Livewire. Why wouldn't that number be real?? It
It isn't real because there is no physical connection between the coolant temperature switch (it's not even a true sender) and the PCM. The number you are seeing is some generated aberration. The coolant temperature switch only connects to the gauge on the cluster.
Who knows what its measuring. It basically generates that number
Yeah, I've had AE tell me that my coolant temp was way below ambient temp. Like that could happen. I learned early on to ignore it.
What is it measuring then?
It's doing a quick pick for tonight's lottery drawing.:grin2:
On a more serious note, I've seen some scanners/apps display their own max preset gauge parameter, when no real value is present in PCM. Hence a steady 250, even on start up.
:grin2: I know nothing! Not a 6 speed.
1 - 9 of 9 Posts
