21 - 24 of 24 Posts
2002 F250 7.3 lariat 4x4 automatic transmission
Discussion Starter #21
Awesome, I did not know that, I will give that a try tomorrow.
1999 ford f250
Another thing that can cause a hard/no start is that if battery voltage drops below 9 volts the pcm loses power and quits firing the injectors. So if you let the glow plugs run till they turn off and it still dont start check voltage while cranking and make sure it stays above 9 (y)
Discussion Starter #23
I have a lot more than just hard start going on, but I'll keep that in mind
Discussion Starter #24
Thanks for all the replies from everyone. I'm still working on the ol girl and will post updates as they happen but I'm in the process of moving too, so splitting time between my house and my mistress of a truck, I'm pretty busy.
21 - 24 of 24 Posts
