I am at the point called desperation.
I have a F350 7.3 ltr.
The truck will not turn over if it has not been run for a day or more. If you plug in the block heater cord , it will turn over. Ford, in the past three weeks have replaced the glow plugs, the glow plug controller on the second visit and last week, replaced all the wiring to the injectors. The tab thus far is over 1,500.00 and the truck will not start unless you plug it in. There are no readable codes and went as far as towing it to the dealership when it would not start so the problem could be duplicated.If you start the truck at least once a day and let it run, it will start the next day, if you go any longer, it will crank til the cows come home but not turn over. Once you plug it in, it will fire up. The exhaust will pop a few times and the engine will proceed to a proper idle and runs perfect after this ritual. I am at a loss as to why Ford cannot figure this out and continually charge me to replace parts that do not resolve the issue.
Any help would be greatly appreciated.
