I originally posted on this truck with a no start/starts after it sits problem that with the help of this forum I have resolved. In addition I had an issue related to white "goop" in the cooling system which after much flushing I have managed to clean out.
I thought I should start a different post for this problem............
Once finished with that, I started the truck, it runs great in park and neutral but when I put it in gear to drive it there is no power. It will move forward and reverse but takes almost full throttle.
A friend of my son's mentioned a possible nonworking variable geometry turbo problem but I don't think this truck has that feature.
It does have an aftermarket Bully Dog turbo control system that reacts like normal when the truck is at idle however when I try to drive it the boost gauge doesn't register anything. I have no paperwork on the Bully Dog so I haven't done any diagnostics on that.
How do I determine if I have the VGT feature? Seems it should be pretty straight forward and from what I can see of the turbo vanes, I don't think it does.. I've attached a picture of the turbo inlet. That should be easy to eliminate.
thoughts?
mike
- I checked the transmission fluid and it's OK. Full, good color, no burnt odor.
- The intake tubes to the turbo are connected at the grill.
- I took the intake tube off and I can see the turbo turning.
- The waste gate line had rusted off at the solinoid, so I plugged the line.
thoughts?
mike
