2000 4x4 7.3 cc lwb 2000 ccswb 2002 ext lb
Having one problem after another with this truck. Now it seems like it's building too much pressure and I am getting motor oil in my fuel filter housing cracking the fuel filter cap anyone have this happen and is the fix injector O rings.Also hpop reservoir is not syaying full and oil gone not leaking external and 150 miles qt oil use.Before didnt use any.Ready to get ride of.
Injector O rings should solve your oil in fuel and the loosing oil problem.
If I remember right there is a check valve in the HPOP that should stop the reservoir from draining
Reactions: DENNY
i put ipr valve in also i check valve. I cleaned fuel filter housing relief valveit was clean.
someone mention that high pressure pump is bad causing reservoir to be empty???
