I am getting the short one JK8 1223 V-Belt but only getting one year / 12,000 miles out of them. They start slipping up grades towing with A/C on. Any other belts or?
Thanks Jeff
If you're only getting 1 year before they start slipping under load, you should look at replacing the tensioner. If it isn't applying enough tension, then the belts would start slipping.
On edit: did you say V-belt? It's supposed to be a serpentine belt.
Sorry its a serpentine belt, I did change the tensioner last time. Any other belts or is Motorcraft the way to go?
I've been using a Gates belt (don't remember the number.) Just replaced the first replacement when the tensioner went out of alignment, shredded the belt and grabbed the dipstick.
Gates K081223HD Fleet Runner Micro-V Belt
It is a green color and you can buy them from WalMart.com for $43 delivered to your door.
are you sure your getting the short belt?
the 10th digit in your vin is supposed to determine what belt you need. if its an x its about 2 inches shorter than the other belt.
