1 - 8 of 8 Posts
Does the CPS always throw a code , changed 3 before and always threw a code but this time no , going to change CPS first.
No it doesn't always throw a code. The CPS can mimic just about every problem possible on this engine.
No not yet was on my way to work , notice power loss and pulled over it was still idling ,put in park and tried to rev a little it jumped a little and died and would not restart ,towed home real quick and went to work plugged in super chip for a code while waiting for friend to tow and it had no codes will change CPS when I get off in morning
What CPS was in the truck?
What did you replace it with?
The BW CPS is supposed to be a good replacement as an aftermarket , if you want a Factory one go with the dark blue Ford CPS.
Not sure about the one I took out but the new is ford but both were grey in color, I will order a dark blue to replace it
1 - 8 of 8 Posts
