Can't open the door from the inside or the outside.
Happened suddenly, outside door handle is loose and doesnt feel to have any tension on it like the others do....
Has anyone had to replace an entire door handle assembly before or is this an easy fix.... Any feedback I could get here would be helpful, thanks!
There was a post about a Supercab rear door that woudn't open a while back. There was a cable that pulled loose. The guy was able to get into the door by pulling the inner panels with the door closed to repair it. Probably a similar thing happened to your truck.
Here's the instructions on removing the door trim. Pretty easy.
