I've got a 2002 f250 7.3
2wd crew cab
When idle it does great when I drive down the road initially it does ok then after about 20 to 30 mph it acts like a bucking bronco and shakes pretty bad when I slam on the pedal it takes off ok and does fine
When I idle it runs fine
When I drive at a consistent speed it shutters and bucks back and forth but when the engine is warmed up it drives fine minor shakes but seems fairly normal
Mechanic said fuel pump and filter did that nothing changed now he wants to do injectors I saw some people in other posts saying tps , pps but not sure any suggestions or ideas ? I bought a pedal assembly to try either way but any other ideas?
2wd crew cab
