I recently tore my truck down to do valve cover & egr delete now I’m having an issue with it shutting off randomly and will not start up unless I unhook my batteries for a minute then it’ll fire right up like nothing is wrong.... any ideas?
I would suggest you scan for codes. ForScan Lite on a smartphone with the appropriate OBDII adapter is around $35. ForScan is a very thorough code reader.
2000 Ford F-250 flatbed 7.3L power stroke with a 4 way chip and 6 spd manual tranny. 285/75/16 A/T
I would use a Ford OEM capable scanner cause they scan a bit better then the smartphone one but that's ur choice
There simply isn't one better at scanning Ford codes than ForScan (even the Litre version for a smartphone) - unless you have IDS .........
