I have a 2003 6.0L and I have a Quadzilla race module installed. The other day I was towing and it started to cut out every once in a while. It was actually a jerk for about a second or less. I have not had trouble up until then. I turned the module off and I still have the same problem. It does it now more frequently. I will cut out as low as 1250rpm just going slow or when the torque converter is locked going down the highway. Is this a problem at the ICP sensor connections? Could a sticking EGR valve cause this problem?
Thanks for your help
