My trans shows hot when pulling my 6000lb trailer only when climbing as soon as I crest the hill or stop goes back to normal within a couple of minutes the guage is factory and doesn't have numbers just yellow and red
Probably need to upgrade to the 6.0 transmission cooler. Could be a bad bypass valve. Also, need to wash out your cooling stack. Lots of debris can accumulate between the radiator and condenser.
OP, if you are curious about your real trans temp then you need a real temp gage. But what RT said also...
Reactions: Mckfast48
