Okay so two questions. First I was driving down the road and I got on it a little and then the transmission started jerking and shifting hard and didn't want to go over a certain gear. The abs light came on and the speedo was jumping all over the place pulled over turned around to pull it into a place to check everything the truck died and wouldn't start, then I towed it to the local diesel shop and they replaced the fan clutch and they got it running again, we'll the abs light is still on and the speedo doesn't work and when it does it just jumps around then ends up quiting? I've put more money bulletproofing it so now I would loose out a lot if I sold it so my second question I have a buddy with the same exact truck that's 4x4 is it easy to just swap the cab bed and motor over to it that's all that's wrong with it because a tree fell on top of it and he's selling it for 1500
