Hi There,
A few years back I purchased a 2004 Ford Super Duty F-250 Diesel 6.0L Automatic (Vin 1FTNW21P94ED50795) which I took to Vanuatu.
It has been at the Ford dealership in Port Vila, Vanuatu for around six months at a cost of over 4000 USD and is no different to when it went in. They have replaced the fuel injection computer module, cleaned injectors, changed filters and serviced. To be honest I don't think they have any idea. This particular model is unknown in Vanuatu.
The problem is if against a kerb or rock or in a shallow hole at standstill it won't rev up or climb over. The engine loads up but won't rev. If the vehicle is pushed back or forward a few inches it will then take off and climb over. On road at speed it seems ok, it changes gears and kicks down as normal. It happens when cold and warmed up.
The opinion I get from mechanics here is that the problem may be in the solenoid operating the torque convertor or in the convertor itself. Also been suggested to replace all injectors.
This is too expensive for me to fix on an old truck. Does anyone have any other ideas on what maybe wrong with it?
thanks
Gus
does it have any code? no rev up can be your fuel system or HPOP system. but if it run fine on street and not under load may be also the transmission??? not a 6.0 or transmission expert but that's my thought. Mark Kovalsky is a formal ford transmission tech, he might come across this and give is 2 cents on it
· Super Moderator
First, I was never a transmission tech. I don't know where people get that idea from.
I don't think it is the solenoid operating the torque converter. If that didn't work right it would just stall the engine.
We need to narrow down the problem to the engine or the transmission. When the engine won't rev, what happens if you shift it to N? Will it rev then?
Another test that might help is a stall test. Put the parking brake on, and with your left foot hold the regular brake pedal as hard as you can. With the trans in D, press the accelerator to the floor FOR NO MORE THAN 5 SECONDS. Read the engine RPM and let go of the accelerator. Let it idle for at least a minute. What RPM did it reach?
To be honest this sounds like a lack of power concern and not necessarily transmission related at all.
Thanks for all advice. The vehicle is not accessible at the moment in a very isolated place. Have borrowed a diagnostic tool and can get to the vehicle in a few days. So will test and come back to you.
