Hey guys, I have a truck driving me crazy. It sat for some time and when I got it it didn't run. I ended up putting a set of injectors in it because I knew 3 were bad. I replaced the hpop because it wasn't building pressure. I replaced the icp sensor and the pigtail because the sensor was blown out. It got a new ipr because something had gone through the screen and I didn't want to risk just rebuilding it only to have to got back and replace it. After I replaced all of this I got the truck running. It starts just like it should and idles fine. My problem us that when I put it in any gear it will not rev past 1000 no matter what. It will in park or neutral but not in any gear. I've looked at all the reading for the pedal and they are all in the desired range. I know its nothing to do with the turbo either because I swapped it with a know good one. I'm running out of things to look at. I'm thinking something electrical but I'm at a loss on where to go from here. I was told to check the maf sensor but that didn't change anything either. Any help would be SO APPRECIATED!
