Replaced the fuse I blew, dash lights came back cab lights came back mirror lights came back. The amber marker lights under the headlights, and tail lights (just the running ones the blinkers and brake lights work) don't work. What went bad? What do I replace ?
Might sound silly, but... Check your turn signal switch all the light run into it, wiggle it around and see if the lights come back on or the fuse blows again. Also, check the wiring for the switch under the dash/near the column, possible pitched wire.
