Hi - I have a 2004 F250 4x4 5.4 that is giving a P0781 code 1-2 shift error. I have done some homework and found that it is likely a solenoid. I have read how to check the resistance of them, so I was going to do that this weekend when I get the pan off. Was hoping maybe somebody knew which one it likely is?
The resistance is fine in all of your solenoids. If it wasn't you would have a code for an electrical problem. It is not at all likely that a solenoid is causing this with no other codes than P0781.
