Hey anyone on here clarify the test for me...
Made my connection to ICP fitting and charged it with 100 psi and powered IPR for a short time and barley saw a drop in pressure. Before powering IPR valve I can hear it draining, which I assume is normal. This damn truck has been a nightmare last few weeks, not the only truck in my fleet so I only work on it here and there. I have a scan guage II, and with a new IPR valve it still goes from 14.8% right to 84.8% when cranking and little to nothing on ICP reading, which gives you your HPOP pressure reading correct??
I replaced STC fitting on pump it had movement in it. Replaced dummy plugs and stand pipes on both rails. New bottom seals on HPOP. And no start still....
And also my cam and crank wont sync on SGII. One of my other running 6.0's sync's up after it fires off. My other one sync's up during cranking right before fire.
Any help would be appreciated. I have both harness' out repairing FICM clips and checking for chaffing. Have to be missing something or not understanding something....
Truck is bone stock, 131,XXX miles
