I drove my truck around town and it was normal. Got home, turned it off, and went inside. Came back out to find that my auto lights were still on, radio was still on, all my warning lights on my dash were lit up. A/C was off though. I checked accessory relay and swapped it, no difference. Unplugged key ignition and nothing changed. When i crank the truck, it runs fine. all the warning lights go off and everything works normally. What could make all the warning symbols light up, radio stay on, odemeter show ------- instead of numbers... The odemeter will tell me when a door is opened, so it can't be a door switch...
Sounds like a ignition switch problem. Did you try cycling it a few times. Can you remove the key while the truck is running?
I can't remove it while it's running. If it helps, I replaced the ignition cylinder and it made no difference. I removed the ignition switch plug to see if it would cut the power off but it made no difference.
