Help!
so I have a 2006 6.0 with a 2004 6.0 motor ( motor had 40k miles at the time
Anyway .. trucks been running good no issues at all then all of a sudden the other day it dies going down the highway , checked the ipr screen was pretty nasty not torn but covered in crap ... thinking that’s the fix I replaced it (screen) still nothing then ended up replacing hpop thinking it was going out still nothing , but Will start on ether as long as I hold the gas any help would be appreciated.
159424
No diagnosing, just throwing parts at it?
Sent from my SM-G988U using Tapatalk
So many questions come to mind (and personally I hate hearing about starting fluid being used, even though it has its place):
Do you have a scan tool?
Have you checked for codes?
Is the '04 engine an early or late one?
Do you still have a functioning EGR system?
Did you clean out the HPOP sump under the oil cooler when you replaced the HPOP?
Did you flush the suction line to the HPOP?
Are you using an OEM oil filter cap and an OEM oil filter?
Are you getting base oil pressure when you crank?
Will the secondary fuel filter bowl quickly fill up with the key on (you have to remove the filter and remove any fuel "standing" in the housing).
When you crank, what cranking rpms are you getting?
What cranking data are you getting for the high pressure oil system:
ICP pressure
ICP volts
IPR % duty cycle
I know it is a lot of questions, but troubleshooting needs to be data driven.
Reactions: 79jasper
