Status
Not open for further replies.
Bought in march drove one week has not run since new it had miss when purchased it would come and go hook my torque ob2 scanner to it no icp voltage so i checked wiring and pulled icp out all prongs where bent straighten them out started up let idle about fifteen minutes run great took for ride went 1 block started missing again forgot to clear codes went back to house cleared codes has not run since had all different codes relating to ficm so I sent off had up graded also had no ficm synec still no run put cam sensor in and complete engine harness injector harness icp sensor and rebuilt pcm when removing injector harness found broken injector plug so I replace #3 injector put in new stile dummy plugs and up tubes for oiling also up graded blue spring in fuel return can hit with little either can get started does not run hardle at all took 1 hour to get to 2000 rpm checked throttle showing 100% has high pressure oil pressure 500 tries to start still don't have sync have 54 volts at ficm ( all new icp cam sensor engine harness injector harness new glow plug harness ficm pcm all up tubes dummy plugs blue spring up grade ) fuel pressure 64 psi looking for answers ipr showing 14% key on when trying to start goes 23% to 35 to 45 % dont know why no sync
Status
