I have a 2006 f350 with a 6.0
Power stroke
I was traveling a long distance
When a lot of white smoke was coming out the back and it seemed to vibrate a bit
I pulled over numerous times
And then I would drive further as I was in the middle of knowwhere
The computer said check engine temp
So I did it didn't seem to bad
I went about 1 more kilometre
Then It had no power and just shut down
You are losing coolant somewhere. Very likely EGR cooler from oil cooler being blocked.
If that message came on it is very unlikely the coolant level is OK. Get it checked ASAP or the repair costs will skyrocket as you do more damage.
