I am considering a 2006 Econoline Chateau Wagon (6.0 PSD/Torqshift Automatic 5-Speed w O/D, 3.55 Differential, HD Tow Package, 8700# GVWR, 16,000# GCWR, 9300# Towing Capacity). It will be an occasional driver, but will do some duty towing within 10% of weight capacities through the Rockies. I have several questions:
1) How good are the factory numbers/capabilities in the real world (e.g. mountain towing in summer) without burning up drivetrain (engine to differential)?
2) Why is the 6.0 PSD de-rated to 235hp and 440ftlbs for the E-Series from 325hp and 570ftlbs in the F-Series?
3) Why no Tow/Haul Mode (only O/D On/Off) availability on the 6.0 PSD, but only on the 6.8 V10 in the E-Series?
4) The 4.10 Differential will buy a 4000# improvement in GCWR (16000# up to 20000#) and a 700# gain in Towing Capacity (9300# to 10000#). Is it worth it, and is it an easy modification (ring and pinion only, or a whole lot more)?
5) What would you do to improve performance (torque, horsepower, cooling) while towing, yet maintain driveability in regular use?
If you recommend modifications (mechanical and/or software), be aware that I don't desire to build the Space Shuttle, but just a greater margin of safety/performance/reliability/flexibilty for my needs. I am not a mechanic, so less invasive (both to my van and wallet) is always a plus. I like the flexibility of being able to change performance profiles from inside the cab, if a chip is the way to go.
I appreciate any and all opinions/advice/experience/perspectives on these matters. Thanks a million...
